Trailer hitch for 2023 CRV Sport Touring Hybrid
Old Jan 11, 2024 | 12:42 AM
Hnguyen's Avatar
Default Trailer hitch for 2023 CRV Sport Touring Hybrid
If you've installed a trailer hitch for this model, please give make and part number. Thanks.
Old Jan 11, 2024 | 09:46 AM
Just Ducky's Avatar
Default Research
I have installed many hitches and base plates on different types of vehicles for many purposes. Your ‘23 Sport Hybrid is different because of it’s electronic feature(s). My go to place for specific info is e-trailer.
My ‘22 has a towing rating of 0 lbs however your ‘23 redesign (Gen 6) has a 1/2 ton rating. So it could be used for a light pop-up, motorcycle, mobility scooter, cargo box or a bike rack. Not much but better than my nothing.
Looking at the e-trailer info it is easy to see that the aftermarket hitches are not recommend for CR-V’s with the hands free tailgate sensor as they will completely or mostly obstruct the sensor.
Sooo, that leaves you with the OEM hitch that has two options. 1. A proper wiring harness and 2. An HFA adapter.
Also notable is that all brands require cutting the body trim.
Everything you need to know, including all three part numbers, can be found here:
https://www.collegehillshonda.com/instructions/crv/2023/trailerhitch.pdf
YMMV
Obviously not a CR-V but this is an example of the level of disassembly you will encounter installing the hitch assembly.
sadie
May 21, 2025 07:59 PM
JRandolph
Jan 31, 2021 12:15 AM
Jhemp3
Jun 13, 2019 07:48 PM
woodman2k
Jul 2, 2016 09:42 AM
Nov 11, 2015 10:02 AM
