Transmission problem in morning, 2007 CR-V
Old Nov 11, 2020 | 11:50 AM
gkarasik's Avatar
Default Transmission problem in morning, 2007 CR-V
Hi,
I'm wondering if anyone else has experienced anything similar:
My 2007 CR-V (105,000 miles) is slow to shift into reverse first thing n the morning. When I first start it and shift from P to R, there's a several-second delay before the car starts moving. Once it starts moving, it's fine the rest of the day. This has been happening for a month. I've changed the fluid and the inline filter, and I've had Aamco do a diagnositc which they say shows no problem. I've searched the forum and the web for similar reports and come up empty. Anybody heard of anything like this?
GaryK
Old Nov 12, 2020 | 02:39 AM
welcome to the forum. slow to shift into reverse in the morning could be from worn seals, lack of proper oil change routine, shift solenoids stating to fail, clod temperature, age of transmission, internal filter debri, low trans oil pressure. what type of fluid was used when trans fluid changed? if anything other than Honda trans fluid, will soon cause a trans failure.
Old Nov 12, 2020 | 09:09 AM
gkarasik's Avatar
I used the Honda transmission fluid. So all of that indeed sounds like a transmission rebuild is required. Is any transmission shop qualified, or is there a specific recommendation?
Old Nov 12, 2020 | 06:59 PM
when my trans started to slip with high milage, i started to ask friends as to whom they would recommend, then looked at the transmission shops and all the reviews. also who gave the best warranty after an overhaul and who had the best cost. also who long will it take to accomplish the job. and how long they hae been in business. you did right by using the Honda Transmission Fluid. how often was the trans fluid changed during the life of the car....just curious. .
Old Nov 12, 2020 | 07:03 PM
gkarasik's Avatar
Every 25,000 miles, so four times.
Old Nov 12, 2020 | 09:29 PM
you did great trans maintenance to your cr-v.( just info) sometimes when applying trans pan sealant, a bit may come off and circulate in the trans fluid. when this gets into a small filter the size of our thumb, it can start to clog and not allow fluid to circulate as needed.
Old Nov 12, 2020 | 09:53 PM
gkarasik's Avatar
Thanks. Can that filterc be cleared or changed without major transmission work? Or is a rebuilt the only option?
Old Nov 13, 2020 | 02:01 PM
that is a cleaned out at rebuilt. only seen when trans is apart. (really unsmart design i think) but its Honda's design.
Randy Ritchie
Oct 10, 2020 11:56 AM
livelife101
Jun 6, 2018 12:53 AM
Asphaltwarrior
Dec 3, 2017 09:16 AM
rescyth
Jun 21, 2007 12:39 AM
daihard
Dec 1, 2006 03:20 AM
