vibration while braking
Old Apr 20, 2009 | 01:11 PM
iep's Avatar
iep
Unhappy vibration while braking
I have 2003 CRV. It started to vibrate when breaking at >60mph. I changed front tires, got it aligned, replaced front rotors and break pads and car is still vibrating but not as much. On the back I replaced only pads. Should I replace back rotors too? What else can cause vibration like that?
Thanks!!
Old Apr 22, 2009 | 05:00 AM
back rotors can cause mild vibration if there are a lot of miles on the rotor. also if the back tires are cupping, this also could cause vibration.
One way you might be able to check the rear rotor is if you pull the hand brake g e n t l y ( easy ) while the car is rolling and see if the vibration is there, ( this only puts the rear brakes on gently.)
rufryder
Feb 6, 2010 02:31 AM
yrk
Oct 20, 2009 02:37 PM
derekcentrico
Jun 5, 2009 06:28 PM
ady5179
Jan 12, 2009 11:41 AM
roses15534
Dec 9, 2007 05:43 PM
