Fit Forum This sporty new sub-compact combines the efficiency of a economy car with the interior room of some minivans.
More Luxurious Ride for 09 Fit
Old Aug 24, 2019 | 09:42 AM
09Fit's Avatar
Default More Luxurious Ride for 09 Fit
Hey hey! I love my '09 Fit. It's nimble, it's sporty, and it hauls a lot of stuff, and it's good on gas.
The only worst part is the suspension is not so nice.
It is just a very bumpy, jarring ride over the roads. Especially any bumps, I really feel them (too much).
It is a ten year old car, with 170,000 miles.
Is there a good solution?
How could I make my 09 Fit have a much smoother ride?
(Without spending too much - let's say $1000 limit max, but hopefully more like $500 USD or less if possible)
Old Aug 24, 2019 | 09:55 AM
09Fit's Avatar
Also there is something wrong with the suspension after hitting a pothole I think.
It's making a jangly, wobbly sound on the left side going over bumps.
I will take it to the suspension repair place.
They say they use Monroe or Moog suspension parts.
Will just getting new shocks from one of these companies make it a much smoother ride??
Old Aug 24, 2019 | 08:01 PM
welcome to the forum. shocks will help, but not much. larger tires with less air makes softer ride but will ware outside of tire faster. I have an 07 with 290k+ it has the original shocks and it is still stiff riding. most economy cars are stiff riding.
Old Aug 24, 2019 | 11:27 PM
Tires make a big difference in ride comfort
And probably one of the best investments in an old car
Got to remember that a heavy car with soft coils make for a boat like ride
However, you vehicle is small. So, only superficial comfort is achievable.
Extra padding on the seats??
Old Aug 29, 2019 | 07:23 AM
09Fit's Avatar
Thanks you two.
So is it really mostly the weight of the car that makes it not a smooth luxurious ride?
Like what if I could put some shocks from an Acura on the Fit - would it ride more like an Acura?
Old Aug 29, 2019 | 08:00 PM
the fit is about 2600lbs, the coil springs are stiff for better suspension and handling, but changing shocks from an acura will not help much. the acura is a lot heavier vehicle. stronger shocks more stiff. changing the tension on the coil if possible would help a lot, but your handling will be mushy, will tilt more and sway more on turns and curved roads. larger tires with lower pressure may help.
usmarine0905
Nov 29, 2012 01:42 PM
mcqueen
Jan 16, 2008 12:41 AM
Nate/The/Great
Dec 9, 2007 05:29 PM
biggiesteves
Sep 26, 2006 06:24 PM
breesej
Sep 19, 2006 04:30 PM
