1998 civic D14A4 noise
Old Jan 17, 2022 | 06:38 AM
KaLuo's Avatar
Default 1998 civic D14A4 noise
https://files.catbox.moe/i5szca.mp4
Is my engines noise something to worry about? I know old hondas make tapping sounds because of the mechanical lifters, is this too much noise? The car is kind of a ****box, worth maybe 500 € so is it worth to do anything about it? I already adjusted the valves but it didn't do anything to the sound but made the performance a bit better. The clearances were actually a bit tight so i loosened them up. So even with tight clearances it was making this sound. Listening on the valvecover with a screwdriver I can hear little bit of tapping but listening the fuel injectors and fuel rail the sound is a lot louder in the same pace. I ran a bottle of injector cleaner but it didn't do anything. There's no tapping sound on cold mornings for a few minutes after starting, I think because then the oil is thicker, but when it warms up and the oil thins out the noise appears. I also changed the oil for a thicker one but it didn't really help.
Anyways, the car runs and works good, only issue is the noise being annoying.
Old Jan 19, 2022 | 02:02 AM
welcome to the forum. older vehicles do make some noise. (like us as we get older the body creeks due to ware) just keep up with the maintenance and it should last a long while.
neustirj
Sep 27, 2021 11:38 PM
luismonarrez1
Jun 11, 2021 07:40 PM
Jojoke
Dec 18, 2009 02:49 AM
atl
Sep 6, 2008 05:07 PM
sebu
May 10, 2007 05:00 AM
