2000 CR-V speaker connections
Old Feb 15, 2019 | 09:35 AM
Jim2V's Avatar
Smile 2000 CR-V speaker connections
Rear clips that were in speaker hole. Bottom one with two wires was attached to factory speaker.
Hi all.
Newbie here and proud owner of 2000 Honda CR-V, that I'm restoring.
Had a question about speakers I"m putting it. When I removed a rear speaker, I found two clips (see pics). The speaker was plugged into clip with two wires. Anyone know what the other clip is for?
Thanks in advance for any help.
Old Feb 22, 2019 | 12:11 AM
Lochinvar's Avatar
The other clip is the tail light connection for a trailer adapter. If you install a tow hitch and want to now trailers the trailer wire converter will connect to that plug.
Old Feb 22, 2019 | 05:30 PM
Is that connector found next to the speaker in the door?
And if it is ... then why would a trailer wire tail light connection be there (instead of being further back)?
Just wondering?
Old Feb 23, 2019 | 09:20 AM
Lochinvar's Avatar
I don't know why Honda put it there, but yes, the trailer wire connector is hidden behind the left rear speaker.
It is also wired to match the car's actual lighting system, with the turn signals and brake lights being separate, so if you want to attach a trailer that uses the American standard 2 light system, you have to plug a converter into it.
dbergan
Dec 6, 2013 06:01 PM
ROC OUT
Oct 7, 2010 10:43 AM
nak88
Nov 29, 2009 01:26 PM
maxmcarthur33
Nov 19, 2009 09:31 PM
rabbithutch
Aug 1, 2007 03:43 AM
