2003 crv starts to miss/ code ?
Old 11-28-2017, 08:20 AM
tmandriscoll's Avatar
Default 2003 crv starts to miss/ code ?
I have a 2003 crv that has started to miss. By this I mean that on acceleration it will sometimes miss, also I notices this pass weekend while on cruise control on the highway it started to miss again. When it does this I backed off on gas and evetionaly (maybe 20 seconds) it ran good. I have checked the air filter and it is not terrible dirty acutually pretty clean. What else should I check. I have run a coupe containers of Sea Foam thru it with no help. Where do I find the port to pull codes so I can have that done? Thanks Terry
Old 11-29-2017, 03:22 AM
would start ta spark plugs, coil pack, wires due to 13 years old..
Old 11-29-2017, 05:16 PM
Thanks, I was thinking of the plugs myself. I will do all the basics new plugs, air filter, (is there a fuel filter to replace?), checked the gas cap seems to be not a problem. You get it, looking for basics but would like to have the codes pulled, can anyone help me as to where that is pulled from, so I do not look like a idiot at my local auto supply store ask to have codes pulled.
Old 12-01-2017, 12:57 PM
fuel filter is in the tank, need to drain tank to get access to the filter. ( I would not touch that my self) port is right side of the steering wheel low looing up is a plug hook up. about shin level.
Old 03-03-2018, 07:47 AM
hichamaziz's Avatar
boombang
02-09-2019 01:43 AM
cutlas
01-23-2016 06:08 AM
frett
07-02-2015 05:57 AM
PlaneguyTed
02-28-2014 10:36 AM
PlaneguyTed
02-27-2014 01:54 PM
Quick Reply: 2003 crv starts to miss/ code ?
