Cluster Lights faded out Help!
Old Jul 24, 2023 | 05:51 PM
btartus's Avatar
Default Cluster Lights faded out Help!
1995 Honda Accord 2.7L
so Im driving home last night and my Cluster lights faded out and then came back on. it happened a couple times. no issue with the headlights.
car has a brand new battery and brand new Denso Alternator.
I just had a new timing belt installed and a couple of engine mounts replaced.
any help appreciated!
bt
Old Jul 24, 2023 | 06:52 PM
Clean the dimmer.
Old Jul 24, 2023 | 06:59 PM
btartus's Avatar
Clean the dimmer.
the dimmer, the little button on the dash that pops out and dims the cluster lights?
or are you referring to the headlight control arm - https://www.partsgeek.com/catalog/19...er_switch.html
can I ask why you believe this is the cause of the problem.
much thanks!
bt
Old Jul 24, 2023 | 10:40 PM
The rheostat that controls the light intensity is on the backside of the button that pops out. Spray it with contact cleaner.
They get dirty and will do this.
Old Jul 24, 2023 | 11:23 PM
btartus's Avatar
ok, so remove the unit from the dash. I assume it pops right out.
Old Jul 25, 2023 | 12:01 AM
btartus's Avatar
any suggestions on the best way to remove the dimmer unit from the dash without damaging the dash?
Old Aug 7, 2023 | 08:45 AM
Bubbalou88's Avatar
I have found that Deoxit5 works better than contact cleaner because contact cleaner while it cleans well it doesn’t lubricate the reostat or poteniometer for longer life.
You could initially use contact cleaner then spray later with Deoxit5. After you spray it, worked it back and forth to wipe the contacts.
multrola
Jul 18, 2021 03:50 PM
EricE85
Oct 26, 2020 11:27 AM
Chris Crumley
Mar 29, 2016 10:09 PM
accoman
Jan 20, 2014 01:41 AM
sia_simba
Apr 27, 2007 12:01 AM
