D16 swap to B16A Clutch Hose Too Short
Old 09-19-2018, 01:03 PM
TheRiceCreamMan's Avatar
Question D16 swap to B16A Clutch Hose Too Short
So I'm swapping my '97 civic's D16 for a '96-'98 B16A out of an SIR II but the stock hydraulic clutch line is too short. Any ideas on what I should use?
Old 09-19-2018, 05:43 PM
welcome to the forum. i believe the hyd clutch line uses the same as the brake fluid, so take the short line and see if you might be able to match the ends to a longer brake hose with the proper fittings. auto parts place has different length lines in stock.
Old 09-20-2018, 01:53 PM
Okay. So I should be able to take the stock fitting off and just run the "brake line" with them on?
Old 09-20-2018, 05:07 PM
yes take your short clutch line to the auto parts place and see if they have longer lines with the same end fittings. replace same for same but longer.
Old 09-21-2018, 11:10 AM
Okay cool I'll try that thanks.
DW_Wood
07-18-2018 11:44 PM
liltrucker410
03-13-2014 04:16 AM
gobabygo95
04-12-2010 09:35 PM
herecometheazn
09-07-2007 02:13 AM
Quick Reply: D16 swap to B16A Clutch Hose Too Short
