Going Turbo
Old Jan 22, 2007 | 10:58 PM
civicracer1997's Avatar
Default Going Turbo
Hey whats up. I am fixing to put a T3/T4 turbo setup on my D16Y8 in my '97 Civic Ex.I plan oninstalling Darton Sleeves in the block to protect against a Blown motor. Im only planning on running 7-8 pounds of boost but I have learned that it is better to be safe. I was wondering if anyone has done this or has any advice. Thanks.
Old Jan 23, 2007 | 12:23 AM
4doorcivic9's Avatar
Default RE: Going Turbo
ORIGINAL: civicracer1997
no need to run Darton Sleeves if you only running 7-8lbs of boost. Good thing to do is though go by some ARP head bolts, and a COMETIC head gasket would also be good. And if you are going do it right by getting bigger fuel injectors and fuel pump, with the boost your running you won't make the power over 400whp so you dont need to change your fuel rail. your stock fuel railis good for 400hp just keep that in mind where u dont go blow money on fuel rail and stuff.
lilholloway121005
Feb 10, 2010 12:38 PM
akaiheart
Aug 15, 2009 10:29 PM
mike0094
Mar 25, 2009 12:26 PM
evidentloss
Oct 8, 2008 05:02 AM
KamilEvolution
Aug 12, 2008 06:38 AM
