HELP! Engine overheating problem???
Old Jul 8, 2013 | 05:44 AM
GilbertF's Avatar
Member
Question HELP! Engine overheating problem???
Here i am posting the problem that I'm facing with my car from last 2 month. My car engine overheats quickly only in small run. I'm unable to understand what's the problem is? Is it a big issue and i need a machanic or it can be solved by myself. I'd already spent so much money on my car and don't want to spend more. So please give me your suggestion that what i have to do!!!
Old Jul 8, 2013 | 10:01 AM
Start with a new cap if no help then try a new thermostst,and if not solved try having the radiator boiled out.
Old Jul 11, 2013 | 05:11 AM
GilbertF's Avatar
Member
Thanks for your suggestions, but there is nothing with the cap, and the other parts you are talking about, I'd replaced them a few month ago, then how its possible that it stopped working? Does it some particular part issue or of whole engine system?
Old Jul 11, 2013 | 10:29 AM
Make sure the thermostat is not in backwards. are the hoses in good condition,a pinched hose due to vaccum can cause overheating.
Old Jul 12, 2013 | 06:33 AM
GilbertF's Avatar
Member
Question
Thanks! Yes, I think that there are some problem(like pinches) with rigid tubes. Now how can i solved this problem?
Old Jul 12, 2013 | 07:42 AM
what have you done to fix the overheating to date. have you checked your timing. if retarded it will run hot. did you put in a used or rebuilt, or new radiator. is your radiator fan working when it gets hot.
Old Jul 12, 2013 | 10:43 AM
I new hose ,old hoses have week spots and can collapse.
Old Jul 15, 2013 | 06:23 AM
Rose Frankie's Avatar
This problem occurs when the engine parts get old or damaged. You can go through http://www.360tuners.com/engine-performance-parts.aspx and you can replace your car's mostly damaged engine parts and thus get your problem easily solved.
Old Jul 16, 2013 | 05:15 AM
Dorisscott's Avatar
Hey, I recommend you to go some local manufacture, during online shopping there may be problems like you can only check products after shipped & payment and if u go for local manf. you can check the product before purchase and if the product is damaged or not suitable; you can easily get replaced it at the spot. On the other side it may take your lot of time to do all this.
Old Jul 18, 2013 | 05:01 AM
  #10
GilbertF's Avatar
Member
Helpful information.
Thanks Everybody!
bleedinblue311
Jan 13, 2014 02:32 PM
eric#16
Sep 30, 2013 11:25 AM
Radiance423
Sep 30, 2013 08:00 AM
jasb750
Aug 25, 2013 12:10 PM
Christlike
Nov 30, 2006 10:22 AM
