OIL FILTER
Old Apr 24, 2007 | 09:47 PM
Corbuston's Avatar
Default OIL FILTER
I havea 94 honda prelude that keeps blowing the seel on the oil filter i cant figure out why this would be happening. its something that i have never seen b4 with any vehicle that i have ever had. i was told that its possible that the oil pump has gone bad in it but im not so sure that is the case. if anyone has any ideas please let me know what the problem could possibly be. Thanks
Old Apr 25, 2007 | 06:39 AM
Default RE: OIL FILTER
wondering what weight oil are you using, and type of oil filter, also does this happen when you rev the engine, or under normal driving conditions, hot or cold.
Old Apr 26, 2007 | 03:50 AM
Corbuston's Avatar
I am using 10 W30 and a penzoil filter i do believe the last 2 times that i have had the oil changed i took it to a shop and thats what they use. i personally have never used penzoil just never really agreed with them but i dont really think that it could be anything like that ii have heard from several people that there is a possibility that my oil pump has gone bad and creating back pressure in the filter blowing out the seal on it.
Old Apr 26, 2007 | 06:15 AM
Corbuston, sorry, I only know about oil pump produces oil pressure low to high, and if too high and cold weather, the seal or filter can burst or blow out the seal. I use a honda or fram, and have never had a seal blown out on me to date. I have seen a filter explode due to cold weather, cold start, 40 weight oil and high rev. too much pressure. Take the car back to the people that changed the filter and ask them why their filter is blowing seals. Might be a filter factory defect
Old Jun 8, 2007 | 12:10 AM
Txaircraftmech's Avatar
sounds like a blowby, change your pcv valve and you need to quit going to that place. Use manufacturer recommeded oil. They are right, I had experience in defective oil filter. There is a plastic flapper inside the oil filter that is not doing its job.
Rfry2010
Jul 27, 2010 08:24 PM
Marc
Nov 13, 2008 02:18 PM
fiveOmar
Aug 3, 2007 09:36 AM
bluerover
Sep 17, 2006 01:25 AM
HondaCVT
Sep 8, 2006 07:55 PM
