over heating b18
Old Jul 10, 2007 | 08:07 PM
biddums42's Avatar
Default over heating b18
I HAVE A 95 EX COUPE W/ A 96 OBD2 GSR B18 IN IT I JUST REPLACED THE RAD BECAUSE OLD 1 CRACKED AND NOW THE MOTOR OVER HEATS IN LIKE 4 MIN.'S I TRYED LETTING THE HEAT RUN WITH RAD OPEN TO TAKE IN WATER BUT IT IS FULL ANY BODY ELSE HAVE SOME SUGGESTIONS!!!!!
Old Jul 11, 2007 | 01:42 PM
Default RE: over heating b18
With the current engine, did the rad that crack work ok, just trying to narrow down if it is the new rad or engine.
The rad you replaced, is it a new one or good used, or overhauled. Did you try to run water from the top to see the flow at the opposite end, before you installed it.
It could be the thermostat, cooling fan, could be an airpocket in the water system that needs bleeding.
Old Jul 11, 2007 | 02:16 PM
biddums42's Avatar
i am going to try to bleed it because it was running fine before just hpoeing i didn't worp the headwhen it over heated or the water pump but thanx for the responce and ideas!!!
hondata86
Sep 11, 2013 05:09 AM
puregunzz
Aug 8, 2010 08:55 AM
nithinbuttime82
Feb 9, 2010 07:49 AM
nkotb
May 23, 2008 08:38 AM
loganschmidlkofer
Jun 1, 2007 08:02 PM
