passport misfire
Old Jun 5, 2010 | 02:00 PM
89hondacrx's Avatar
Default passport misfire
have a 99 passport ex 4x4 with 3.2L in it. the engine light is on and it says cyl 1 misfire. i checked the injector with a screw driver it does click. i unhooked the coil pack while it was idlin and it didn't change so thought it was coil pack so i switched coil packs and no change. i tried carb cleaner around intake gasket no change.checked for burnt valve with paper at exhaust didn't suck it in.changed fuel filter anybody know what else i can try the only thing i can think of is having a compression test and the computer checked
Old Jun 6, 2010 | 05:44 AM
did you check the spark plug for dropped porcelin ( center white piece) wire for condition or leak. compression test is good also.
Old Jun 6, 2010 | 07:02 PM
89hondacrx's Avatar
Unhappy
did a compression test today cylinder 1 only had 60psi the rest were between 160-190,i put a little oil in cyl 1 and it got up to 120psi.i'm about 98% sure that means bad rings i really hope it could mean something else. was wondering if anyone knew ball park figure how much it would cost to have rebuilt.
jim cahoe
Oct 19, 2011 11:45 AM
Tommy504
Nov 5, 2009 08:24 AM
brikcity
Jan 9, 2009 04:32 AM
buster87
Aug 13, 2008 04:15 PM
chiman
Feb 25, 2007 10:58 AM
