06 accord chug & stall
Old May 31, 2010 | 12:01 PM
digger785's Avatar
Default 06 accord chug & stall
engine light on, and off, hesitates when beginning to accelerate, chugs and sometimes stalls out.
Old Jun 3, 2010 | 11:25 PM
jaydawg30's Avatar
Member
if all possible pull the code that triggers the check engine light with a diagnostic tool. This could be caused by a few things like EGR, PCV, or fuel system not working properly. The easiest to test is the PCV Valve which is located on your valve cover. Carefully remove it and shake it . If it rattles, the valve works. The other test require a little more... Some simple things to check are make sure the battery terminals a properly clamped down and are not corroded.
HONDASHOW
Nov 23, 2011 12:16 AM
stroker
Jan 17, 2011 06:54 PM
kentucky
Sep 10, 2009 08:42 AM
genaro626
Jul 24, 2009 09:37 PM
vstoneinc
Mar 28, 2009 12:42 PM
