91 accord not starting
Old Sep 9, 2007 | 04:57 PM
paulr0859's Avatar
Default 91 accord not starting
ok. my accord was doing fine for a few weeks, but then it decided to not want to start easily. when i turn the key, it just keeps turning over and not firing. but, it always eventually does start, sometime after 2 minutes, sometimes 20. i have to take a break from cranking for it to start. also sometime it will start and then after a second, just die. any ideas to what the problem could be?
Old Sep 9, 2007 | 08:27 PM
fastasf*ck21's Avatar
Default RE: 91 accord not starting
my accord did the same thing. might wanna check your starter, an if not that then ur altenator. mine was my altenator, an im goin to be honest..... its a pain in the *** to change out man
Old Sep 10, 2007 | 09:05 AM
fuel pump failing, distributor failing, spark plugs worn, main relay bad, ecu burnnt out. need to get a manual to assist you to complete the checks needed to see each item that may be failing or is bad.
minibutton
Jul 8, 2011 01:10 PM
puneet
Dec 20, 2010 10:31 AM
HondaChyck09
Dec 24, 2009 05:12 PM
mohd3333
Dec 12, 2009 03:15 AM
akilinski
May 15, 2009 11:35 PM
