Do valves really need to be adjusted?
Old Mar 27, 2009 | 07:07 AM
mike0094's Avatar
Member
Default Do valves really need to be adjusted?
why do valves need adjusting? i think mine need some adjustment.... is it critical to adjust them?? i dont really want to take the cover off and risk damaging something if its not that important..thanks
Old Mar 27, 2009 | 03:20 PM
when I had mine adjusted, I asked the mech why adjust other than they started to get a little noisy, said if valves not open correctly valve lip can start to burn away, if open to much gasses escape in or out and cause pop on the intake side or pop in the exhaust which will cause the sensors and cat to go bad.
Old Apr 20, 2009 | 08:40 PM
fuji576's Avatar
Default accord valve help
Hey whattdya suggest. My end 3 valves, front exhaust side clicks very loud and doesnt hold compression enough to start. What should I do. Sounds like you talked with someone who was knowledgable at it. Please if you can. Thanks, Jason
Old Apr 26, 2009 | 10:29 PM
fuji576's Avatar
I fixed it in 3 days w/my lil bro and a ****ty basic tool set saving a 1000 dollars. Still clicks though. I wish you **** new a little then maybe it wouldnt.
paturner51
Oct 21, 2013 05:21 AM
mike0094
Apr 26, 2009 10:24 PM
skeenr
Mar 17, 2009 12:51 PM
JJJeff
May 18, 2008 01:57 AM
gerry
Apr 3, 2007 05:09 AM
