Replace IAC on 2000 2.3 VTECH
Old Sep 30, 2012 | 09:02 AM
elang's Avatar
Default Replace IAC on 2000 2.3 VTECH
I need to clean or replace IAC. It looks like it is attached to back side of intake manifold. How tough a job is it.
Old Sep 30, 2012 | 02:35 PM
lowlife9's Avatar
remove a couple coolant lines and unscrew a couple screws or bolts. just make sure if its a philips head screw you use the correct size or you will stripe them.
Old Oct 6, 2012 | 08:09 AM
elang's Avatar
I can't get at it. Does anyone have a picture showing the exact location of IAC on this engine, 2000 LX, 2.3L V-TECH.
Old Oct 7, 2012 | 01:04 AM
lowlife9's Avatar
its attached to the throttle body with coolant line coming out of it. http://www.6thgenaccord.com/forums/s...ad.php?t=20714
Old Oct 8, 2012 | 07:03 AM
elang's Avatar
Thanks for a great link. It explained everything. I will be attempting next weekend. Thanks again.
Old Oct 13, 2012 | 09:30 AM
elang's Avatar
That was great a link and removed IAC no problem. When cleaning do you remove electronics or leave them attached.
Old Oct 22, 2012 | 03:08 PM
elang's Avatar
Cleaned IAC, installed with new gasket but the problem returned. Engine rpms increase and decline. Anyone have any other ideas.
Old Aug 24, 2019 | 01:44 PM
s-ayubi's Avatar
Replace the IAC... its a common issue in Honda's . Get one made in China for under $30.00 like I did … works perfect.
Mike da wrench
Feb 9, 2016 01:22 AM
#1moe
Apr 17, 2013 04:07 PM
GStevison
Sep 2, 2009 12:39 AM
Zackcal1899
Dec 9, 2007 05:29 PM
96 Civic Ian
Dec 15, 2006 08:28 PM
