Need Help with 2001 Maintenance
Old Dec 15, 2010 | 11:34 AM
vbarlow's Avatar
Question Need Help with 2001 Maintenance
I have a 2001 Honda Civic with 154,000 miles. I brought a brand new engine from honda less than 2 years ago and replace the transmission with a used one about a year ago that had approx 40,000 miles on it.
My question is:
I am unsure about the maintenance that I need to do. Since I have replaced the engine and transmission, what are the other major parts that I should have checked out to ensure that my civic last. Like any fluids flushed? Or belts replaced?
I have also recently replaced...
The front struts
Lower control arm bushing
Front/Rear brakes & Tires
We asked honda to do a full diagnostic on the car and they said it would be $150. Even though that would applied to any work done, it would keep me bound to getting the work done there. I dont mind paying for the work but I dont want to be ripped off.
Any suggestions? Thanks!
Old Dec 16, 2010 | 04:32 AM
welcome to the forum. Suggest you get a factory service manul. ebay does sell them. most of the work you can handle yourself. Transmission drain and flush each 3 years or 30k miles using honda trans fluid only. if driven a lot, once a year will not hurt. clean out your idle cut off vlv, throttle vave control. flush radiator each 2 years. cabin filter ea 30k miles. if you go to the honda site, it does have a schedule maintenance you can follow. Also the owners manual has a schedule maintenance sheet.
Old Jun 14, 2012 | 08:55 AM
vipercarcom's Avatar
Default Need Help with 2001 Maintenance
Annual checks are: antifreeze, brakes, distribution nelt, dampers lambda, probe filters and motor oil (they are replaced every year or 20,000 km). Do not have to replace them but must be checked
Old Jun 15, 2012 | 01:43 AM
lowlife9's Avatar
whats a probe filter sounds sexy.
Old Apr 21, 2013 | 03:59 AM
i mean oil, air, AC, fuel filters
Old Apr 23, 2013 | 11:19 AM
Alan's Avatar
Hi !
If you diden't change the coolant every 3-4 years, it would a good ideea to change the radiator to. Some times, due to poor coolant quality and iregular changing intervals some elements of the radiator can be filled with a thik smuge.
Hope this info helps.
dgalati000
Feb 5, 2010 11:30 AM
sirjune
Jun 22, 2008 05:30 PM
nphadro
Jun 18, 2008 09:17 PM
sidearm17
Jan 6, 2007 05:19 PM
hd3
Nov 15, 2006 12:56 AM
