Honda Civic 1998 Turtle crawl " HELP"
Old Oct 30, 2008 | 07:35 PM
James45's Avatar
Default Honda Civic 1998 Turtle crawl " HELP"
Hello,
Here is my problem and i hope some one can help me that has had the similar problem. I have a 1998 Honda civic DX, and one day i was driving it and all of a sudden it didnt want to go. The engine light came on and i had my foot down all the way on the accelerator and it was barely moving. I puuled over and I turned it off and waited for a while and turned it back on. The engine light was off but when i put it in drive it barely was moving with my foot all the way down on the accelerator. As it picked up speed about half a blockthen it shifts and continues normal acceleration, until i come to a stop sign or a stop light. Then the process starts all over again with a crawl at first and then it picks up speed then it shifts to normal acceleration. " Can some one here HELP me please i dont want to crawl like a turtle anymore. Thanks for anyone that can help in advance.
Old Nov 2, 2008 | 11:41 PM
Default RE: Honda Civic 1998 Turtle crawl " HELP"
welcome to the forum. Check to see if your exhaust system is flowing good, clear path, sometimes the cat fails and cloggs the system. Also check your fuel path and fuel pressure is good at the rail.
Old Nov 4, 2008 | 01:12 AM
James45's Avatar
Hey thanks for your reply. Im not too sure where or how to start......
If you dont mind me asking how do i check the fuel flow? or do i check to see if
there is s glog somewhere. And how do i check that? Sorry but i can do the work i
just dont know where to check or begin. Thanks for your knowledge.
James
Old Nov 5, 2008 | 04:11 AM
to check fuel flow, need a pressure guage to attatch to the fuel rail, the fuel rail has a fitting that has a platic/rubber cap that looks like one on the tire. Need to read the service manual, hynes, chilton, factory, or at the local library on what the actual pressure should be on your car, Last numbers I read were approx 28 lbs. Also did you check your fuel filter first or change it. Normally fuel filter don't need change for far over 130k. miles.
Old Nov 5, 2008 | 11:42 AM
James45's Avatar
Thanks for your help acmech52,
I will check the fuel filter first and if that's not it, i will check the fuel pressure. Thanks again and i will keep you posted.
James
tomcalwriter
Nov 3, 2010 08:02 PM
mikhail1991
Sep 3, 2010 02:44 PM
inline4
Sep 20, 2006 08:06 PM
hondaex
May 19, 2006 01:12 AM
1998HondaCivic
Jan 20, 2006 02:13 AM
