whining noise
Old Apr 24, 2013 | 12:47 PM
ThrownClear's Avatar
Default whining noise
Hey all I have a '99 Accord DX that makes a whining noise only when the car is moving. It increases in volume when I apply the brakes, but not in pitch, and it does not get higher/lower or louder with speed. I checked the pads, there is still meat on them though they will need to be changed before too much longer. Any suggestions? Thanks...
Last edited by ThrownClear; Apr 24, 2013 at 12:48 PM. Reason: needed to add something
Old Apr 25, 2013 | 03:29 AM
welcome to the forum. the brake pads have a piece of metal, "tattle tail" makes a high pitch sound to advise you that the pad is getting close to change time. and it does get louder when the brake is applied. it is on one side of the pad, usually the inside pad. check to see if it is wearing on the rotor.
Old Apr 25, 2013 | 09:29 AM
One of the clips could have come loose in the brakes.
Old Apr 25, 2013 | 11:26 AM
If that was the case wouldn't the sound change as you went faster? Wouldn't it get higher in pitch? I'll check it out for sure, there's meat on the pads but they do need to be changed. I'll just go ahead and change them all out. Thanks guys, have a great day!
Old Jul 18, 2013 | 05:19 AM
GilbertF's Avatar
Member
Yes, there may be a metal piece or screw come in or under the brakes. There may be other issue so check it carefully. If you thinking about change or replace it there are so much performance part that can improve such problems and also increase performance and life span of your car.
toicy4ya
Mar 19, 2011 01:55 PM
Accrd5spd
Jun 23, 2010 03:05 AM
leon718
May 22, 2008 10:09 AM
tarheel1
Aug 23, 2006 02:58 AM
Bob1822
May 5, 2006 11:09 AM
