whining noise
Old 04-24-2013, 12:47 PM
ThrownClear's Avatar
Default whining noise
Hey all I have a '99 Accord DX that makes a whining noise only when the car is moving. It increases in volume when I apply the brakes, but not in pitch, and it does not get higher/lower or louder with speed. I checked the pads, there is still meat on them though they will need to be changed before too much longer. Any suggestions? Thanks...
Last edited by ThrownClear; 04-24-2013 at 12:48 PM. Reason: needed to add something
Old 04-25-2013, 03:29 AM
welcome to the forum. the brake pads have a piece of metal, "tattle tail" makes a high pitch sound to advise you that the pad is getting close to change time. and it does get louder when the brake is applied. it is on one side of the pad, usually the inside pad. check to see if it is wearing on the rotor.
Old 04-25-2013, 09:29 AM
One of the clips could have come loose in the brakes.
Old 04-25-2013, 11:26 AM
If that was the case wouldn't the sound change as you went faster? Wouldn't it get higher in pitch? I'll check it out for sure, there's meat on the pads but they do need to be changed. I'll just go ahead and change them all out. Thanks guys, have a great day!
Old 07-18-2013, 05:19 AM
GilbertF's Avatar
Member
Yes, there may be a metal piece or screw come in or under the brakes. There may be other issue so check it carefully. If you thinking about change or replace it there are so much performance part that can improve such problems and also increase performance and life span of your car.
toicy4ya
03-19-2011 01:55 PM
Accrd5spd
06-23-2010 03:05 AM
leon718
05-22-2008 10:09 AM
tarheel1
08-23-2006 02:58 AM
Bob1822
05-05-2006 11:09 AM
Quick Reply: whining noise
