Codes help!!
Old 12-21-2020, 02:20 PM
Freddie Lee's Avatar
Default Codes help!!
I know how to get the slide doors to work again by pulling the fuse.
I put it off for a while cuz I couldn't remember which fuse it was. I decided to do it I had the ignition on and just pulled four or five fuses until I found the right one!
Problem is after I did that I started driving the truck the two oxygen sensor codes came up 155 and 135. I don't have a problem changing the sensors but I feel it might be an electrical thing!! I have a scanner but the codes won't clear, it will go off, I can hear a relay switch in the passenger side kick panel click and the codes immediately come back on!!
Did I screw something up by pulling fuses in the small interior box with ignition on or is it the sensors??? Just seemed too coincidental to me!! HELP PLEASE
Old 12-21-2020, 06:48 PM
welcome to the forum. check all fuses under the hood and the ones you pulled to make sure they are all good.
jackraider
03-18-2015 03:20 PM
cpj08
08-25-2013 11:58 AM
iamatt
08-13-2013 10:38 AM
jjmcox
02-15-2010 09:01 AM
civicpryde
02-25-2008 07:34 PM
Quick Reply: Codes help!!
