Just bought a 2010 AWD...tranny questions
Old Oct 2, 2019 | 03:26 PM
jim_w's Avatar
Default Just bought a 2010 AWD...tranny questions
Bought 2010 AWD CRV last night. I didn't really give it a good test drive until this morning. It shudders (I compare what it is doing to an old manual trans when you are in high gear and going to slow). Does it at around 30 to 40 mph...especially on a uphill grade. Its like its not downshifting. Any ideas? I'm reading all sorts of horror stories!! I got a 6 month warranty on the drive train, but I'm wondering if it can be even fixed!
Confidence is low...I repeat "Confidence is low!..lol
I hate this because I really like everything else about this little SUV! It's my first Honda...
Old Oct 2, 2019 | 04:14 PM
RenegadeX's Avatar
First and easiest thing to do is try looking at the tranny fluid. If it's anything but red, you might want to consider changing it and seeing if that helps. Pretty easy to do on the CR-V. There's a drain plug on the tranny pan. Loosen, remove and drain. I always measure how much drains out so I know how much to put back in (if your confident that the fluid level was correct originally). I think you need a crush washer when replacing the drain plug. Good luck!
Old Oct 2, 2019 | 04:23 PM
jim_w's Avatar
Thank you. I will go check it. Do I need to get OEM fluid if it does need changing?
Old Oct 2, 2019 | 07:34 PM
jim_w's Avatar
I checked the fluid..color was red and looked pretty clean. Level was good too.
Old Oct 2, 2019 | 07:38 PM
jim_w's Avatar
I drove it again, and I can reproduce the issue easily now. I can slow down to about 40mph, from my normal highway speed, and slowly try to speed back up, and it happens every time. Feels like it isn't downshifting correctly and is trying to start back off in too high a gear.
Old Oct 3, 2019 | 02:29 AM
welcome to the forum. If the trans fluid is red and clean, need to find out what type of trans fluid was used, if no one knows, take the vehicle back to the dealership and get them to fix the transmission. ( must use Honda transmission fluid only on all honda's). Read the 6 mos warranty on the drive train and see if you have to pay for 1/2 of the repair. many times if you buy a honda from a used car sales and not a dealership, it's because it has some type of problem and sold to the car sale whole sale. check the entire drive system before taking it back to the sales lot to fix anything else found. DO NOT CHANGE THE FLUID YOURSELF, IT WILL VOID THE WARRANTY.
Old Oct 14, 2019 | 05:03 AM
jim_w's Avatar
Wanted to add a followup comment..I had the Honda dealership flush the transmission and torque converter on my 2010 CRV-EXL. The above mentioned problem went away, but they said if it re-appeared that the torque converter would have to be replaced! They quoted 1800.00 for replacing converter! It was over 200.00 just for the flush!
I still notice a slight vibration at certain speeds/loads but not enough to stress about!
Old Jul 24, 2021 | 02:32 PM
markfer's Avatar
Default Similar problems in 2013 CRV
Hi I'm having the same vibrations around 40-80 kph and decided to look under the vehicle.
I have read about the torque converter issue and that seems to be the problem I guess? After looking under my vehicle I noticed slop on the axle where it joins ...something (pic included). I also noticed moisture on the other end that connects to the transmission. Any idea what it might be?
Thanks!
Red arrows point to where I see moisture and slop build up that looks wet.
One end with the slop
Another area i see wetness. No clue what it is.
Cultcab
Nov 29, 2014 06:48 PM
wayne0
Nov 1, 2012 07:55 PM
Rustyb
Jul 28, 2011 12:22 AM
mike0094
Mar 26, 2009 01:31 PM
fondario
Jun 15, 2007 04:32 PM
