Timing chain
Old Jan 6, 2019 | 06:03 PM
jeffsch's Avatar
Default Timing chain
I have a 2003 Honda CRV. How can I tell if the timing chain has skipped a tooth? Simptoms are engine light goes on and sometimes blinks Doesn't start sometimes after sitting awhile.I've replaced the fuel pump,injectors,plugs and rotors
Old Jan 7, 2019 | 12:11 AM
welcome to the forum. timing chain jump runs bad to not run. does not matter hot or cold. possible bent valves, normally engine stops running.
Old Jan 9, 2019 | 10:29 PM
When it doesn't want to start, (crank, no start) check for
Fuel
Air
Spark
Timing
Exhaust
Compression
Old Jan 12, 2019 | 12:45 PM
Lochinvar's Avatar
There you go, back to basics. I'm saving that response, thanks!
Finch Platte
Nov 19, 2019 03:21 PM
TCV
Sep 5, 2019 08:13 PM
00Vette
Apr 1, 2015 10:01 PM
Ctucker1
Jun 8, 2010 10:15 AM
brad66247
Dec 31, 2008 08:25 AM
