EGR code
Old Mar 31, 2016 | 02:22 PM
Bob2000's Avatar
Member
Default EGR code
My wife's 2000 Accord with 2.3L just kicked up a check engine light for the EGR (she took it to the Honda dealer to read the code). They told her it needs the EGR port cleaned, and maybe a new valve installed. They want 200 in parts, and 480 in labor to do the job. How hard/bad is it to clean the port? Is this a pull the intake manifold and the valve off, and "roto rooter" it? Or is there more stuff involved going on that I'm not seeing? The dealership says it's most of a day job.
Thanks for any insight you can offer.
Old Apr 1, 2016 | 06:09 AM
if you get yourself honda accord service manual, it will show you how to clean a egr valve. it goes into the exhaust sys, no intake.
Old Apr 2, 2016 | 11:45 AM
Bob2000's Avatar
Member
I do have the factory service manual, and it DOES show the valve being bolted onto the intake manifold (located between the FPR and the thermostat housing). The book explains testing the valve electrically, and replacing it, but nothing on cleaning out the ports. This is why I asked how hard/bad of a job it is. I'm guessing the exhaust side of the port must be off #4 cylinder (since the valve is located on that end of the intake manifold), and run thru the head (probably under the cam) and to the intake manifold port that the valve is dumping into. It is an Exhaust Gas Recirculation valve after all. In the past I've just replaced the valve, not cleaned out the port, as it's never been a port being clogged issue.
Old Apr 21, 2016 | 02:44 PM
Bob2000's Avatar
Member
Well finally got to doing this job. Carb cleaner sprayed into the port opening ends got that part of the job done. Ended up replacing the valve as well, as it tested bad according to the FSM (not enough lift). While I had the car in the garage, I also replaced the front rotors (old ones were thin), knocked the drums off to inspect both the drums and shoe thickness, and gave it a much needed tire rotation. The car should be good to go now for a while, as we have an upcoming trip we're going to take in it.
Old Apr 23, 2016 | 08:07 PM
cueball21's Avatar
Member
Well done, Bob2000! You saved yourself some cash and took care of some much needed maintenance, too.
Gotta love a Honda!
Old Apr 24, 2016 | 09:05 PM
Bob2000's Avatar
Member
Gotta love a Honda!
Thanks. I figure I saved at least 500 bucks, which got offset with what I dumped into my 97 Accord, just trying to get it to run.
PaulPool89
Aug 19, 2014 06:40 PM
usahoe18
Feb 27, 2014 08:23 AM
HondaJohn
May 22, 2010 02:53 PM
jim97gst
Jan 27, 2008 02:28 AM
Carl95
Feb 24, 2007 09:29 PM
