P1607
Old Apr 17, 2024 | 10:44 AM
Drew Peeler's Avatar
Default P1607
I have a 2000 accord and i cant clear the code p1607, so i figured i need to get a new pcm. I got one from the junkyard with an ignition switch from the same car. Do i still need to have it programmed to work with my key?
Old Apr 17, 2024 | 10:59 AM
The ignition they sold you has no key?
Old Apr 17, 2024 | 06:20 PM
i bought the ignition switch and pcm from the junk yard with no key. I was told that the pcm wouldnt work without the ignition switch, so i got both. Do i still need to program the key because it has a chip in it, or is that why i was told to get the ignition switch that goes with the pcm?
Old Apr 17, 2024 | 06:22 PM
its the ignition switch i have, not the cylinder that the key goes in, but the part after the cylinder. Does that make sense?
Old Apr 18, 2024 | 06:28 PM
When the key goes into the lock and turned, the keyless entry receiver/immobilizer send out a signal to the key. The transponder in the key send a signal out. It contains the key code and engine code. If they match what the immobilizer has then it sends a signal to the ECM to say it is okay to start engine. That signal also has the key code and engine code. If they match then the engine will start and run. If not then it might start with whatever fuel is left in the system. But, it will stall and not be able to restart engine.
Replacing the ECM with a junkyard one means you should have the ECM and the key. You will need a high level scanner to program.
That ignition switch is just the electrical switch. The one in your car should work fine.
Old Apr 19, 2024 | 12:55 PM
https://www.youtube.com/watch?v=z6GJOqy70mQ
thank you for your response. I appreciate you.
sruggieri09
Feb 14, 2022 07:45 AM
Rockabetty78
Apr 10, 2021 07:59 PM
cordovan66
Apr 12, 2015 07:38 AM
squirt31111
Oct 4, 2012 07:21 AM
michael
Jan 19, 2007 04:57 PM
