Water in oil, need advise
Old Jan 8, 2007 | 05:44 PM
Honda house's Avatar
Default Water in oil, need advise
My stock 91' Accord quit running recently. I pulled the plugs and noticed they were wet with water/gas. I cleaned and dried them and the car started right up. Eventually the car died again. I pulled and cleaned off plugs again and it started. I ran a compression test and came up with 190,170,172 and 175. No apparent leak. When I removed the valve cover I did see the brown milky oil/water, a leak somewhere. What I find strange is that the plugs show no sign of the milky brown oil/water on them, only clearwater/gasoline. How can this water enter the cylinders without first mixing with oil? Any advise would be appreciated.
Old Jan 12, 2007 | 01:29 AM
accordh22a's Avatar
Default RE: Water in oil, need advise
sounds like a bad head gasket. and your 2-4 pistons compression isnt right. or your #1 is high for some reason
Old Mar 17, 2007 | 01:45 PM
would you know if your engine was ever overheated? overheat may cause the head to crack and allow water in.
Old Mar 28, 2007 | 11:28 PM
jombolo's Avatar
Its definately a headgasket problem. Make sure that if you are going to keep this car, to get the head resurfaced when you get the head gasket fixed, otherwise you are going to have bigger problems in the not too distant future. i.e. if the head is cracked or damaged.
Old Apr 7, 2007 | 08:44 AM
jdmhondaman's Avatar
i would change the oil and sounds you need a new head gasket
Mr.Dread
Feb 20, 2015 03:50 AM
CJindiana
Feb 7, 2015 10:23 AM
TheRedViper
Feb 2, 2015 07:24 PM
skidoorcng
Mar 2, 2014 08:30 PM
Delgado2k6
Dec 3, 2007 05:11 PM
