2006 Odyssey, Repair or replace??
Old Dec 4, 2022 | 04:25 PM
cool-blue's Avatar
Default 2006 Odyssey, Repair or replace??
I have a 2006 EX-L with 280K miles that I have had and maintained since summer 2016. I think the repairs it needs are about equal to the values of van. It is due for timing belt/water pump. The front suspension needs replaced. Rear shocks too. There is a significant oil leak, maybe 2. I took it to my mechanic to have him look at the oil leak. His guess is the aft valve cover or the Vtec module gasket. The RH side of oil pan is wet like the front main might be leaking. It could be the oil pump. We had it resealed (by dealer) when we got the van at 165K. It needs 2 tires as well. At the moment the van runs well and the transmission is functioning well. I have done a couple of drain and fills in the last 18 months. My independent mechanic has told me that it might be time to look for a replacement as he doesn't see the Oddy's run well past 300K. What are the end of life experiences of the membership here?
Now is not the best market timing to get a deal on a $10k used vehicle. If we make the investment, I am looking to get another 5 years out of it just because that should be the life of timing belt.
Old Dec 4, 2022 | 06:33 PM
I'd drive that thing until the wheels fall off. Basic oil and tires only. That timing belt may be good for another 5 years. I've seen them with 250K miles.
Old Dec 8, 2022 | 07:58 PM
cool-blue's Avatar
I appreciate the reply. The intent is that we no longer enjoy the ride but we would like to. I'll need to invest in this lumber wagon to make that happen. 2 more options. You noted one, just drive it to failure. The third would be to sell it and start again with a different vehicle. Wife is ready to move away from a minivan on the next vehicle. She is thinking RAV4 or CR_V
Old Dec 8, 2022 | 10:04 PM
I don't know why you asked about repair if you are not keeping it.
Old Dec 9, 2022 | 04:32 PM
cool-blue's Avatar
I’m not opposed to keeping it. Keeping it necessarily means updating the front end because it’s not pleasant to use for the next 5 years. The point in asking the first question was to determine if I had a reasonable expectation to get another 100k. YES would seem to be your answer and I thank you for weighing in on the subject.
Old Dec 9, 2022 | 06:42 PM
Communication using a medium as this leaves a lot to be desired.
OLDPilot
Aug 10, 2021 10:09 AM
Dallas74
Apr 5, 2019 02:00 PM
rbbtmackdaddy
Feb 5, 2013 12:57 PM
asimo
Jan 20, 2009 02:45 AM
jonsaysthat
May 28, 2008 06:54 AM
