03 Pilot Transmission Range Sensor Need Help
Old Jan 3, 2025 | 09:47 PM
Chazhorse13's Avatar
Default 03 Pilot Transmission Range Sensor Need Help
My 03 pilot displayed P and D on the dash. All the accessories worked but it wouldn't crank wouldn't start. My mobile mechanic and I did some homework and deduced it was the transmission range sensor (neutral safety switch). I got a new sensor, plugged it in (but didn't install it) and rotated the sensor to Park. I verified the sensor was working as it would now display other gears besides P and D. It would show D1 and D, D2 and D and so on and so forth. But I still can't get the D to stop illuminating, there for, it still won't start. I disconnected the battery for 30 min to clear the ECU. Other leads suggested that I need to clear the body control unit. How do I do that and is that a good course of action? Any other ideas. The unit is just resting on the engine, all trouble shooting was done while it was hooked up but not installed.
Any help would be greatly appreciated.
~best, Chaz
Old Jan 4, 2025 | 11:31 AM
Operation CHARM: Car repair manuals for everyone.
Home >> Honda >> 2003 >> Pilot V6-3.5L >> Repair and Diagnosis >> Transmission and Drivetrain >> Automatic Transmission/Transaxle >> Transmission Position Sensor/Switch >> Service and Repair
Transmission Position Sensor/Switch: Service and Repair
Transmission Range Switch Replacement
1. Raise the vehicle, and make sure it is securely supported.
2. Shift to the [N] position.
3. Remove the transmission range switch connector (A) from its connector bracket (B), then disconnect the connector.
4. Remove the harness clamp (C) from its bracket (D).
5. Remove the clamp from the clamp bracket on the transmission housing, and remove the harness holder (A) from the end cover (B).
6. Remove the transmission range switch cover (C), then remove the transmission range switch (D) from the end cover.
7. Set the new transmission range switch to the [N] position. The transmission range switch clicks in the [N] position.
8. Install the transmission range switch (A) on the control shaft (B) gently, then secure it with the bolts. Do not move the switch when tightening the bolts.
9. Install the transmission range switch cover (C), and the harness holder (D) on the end cover (E).
10. Connect the transmission range switch connector (A), then install it on its connector bracket (B).
11. Install the harness clamp (C) on its bracket (D).
12. Turn the ignition switch ON (II). Move the shift lever through all positions, and check the transmission range switch synchronization with the A/T gear position indicator.
13. Check that the engine can start in the [P] and [N] positions, and cannot start in any other shift lever position.
14. Check that the back-up lights come on when the shift lever is in the [R] position.
15. Allow the all wheels to rotate freely, then start the engine, and check the shift lever operation.
pro multis · About Operation CHARM
crashmarvin
Oct 6, 2023 01:00 PM
whatarush
Oct 8, 2016 10:10 PM
igor2009
May 4, 2016 06:22 AM
shortys3923
Dec 7, 2008 10:39 PM
celoftis
May 28, 2008 05:41 AM
