02 crv condenser fan runs constantly
Old Dec 12, 2023 | 03:12 PM
Mcfam's Avatar
Default 02 crv condenser fan runs constantly
My cooling fan doesn’t work (jumped with power on pigtail) so I think it is bad but my condensing fan runs all the time if I hook up temp switch on radiator. If I unplug the temp switch it operates correctly, coming on only with the a/c. Do I have another problem with that fan or is the temp switch bad or is there cross wiring somewhere?
Old Dec 12, 2023 | 07:49 PM
Ground?
Old Dec 13, 2023 | 09:04 AM
Mcfam's Avatar
Which ground?
temp switch, condenser fan, or cooling fan?
Old Dec 13, 2023 | 09:47 AM
You want to test the fan motor you need power and GROUND to test.
Old Dec 13, 2023 | 10:40 AM
Mcfam's Avatar
I was jumping with a hot and ground from battery, sorry about the miscommunication. Any ideas on the condenser fan running constant ( turns on as soon as I turn the key on) when the temperature switch is plugged in?
Old Dec 13, 2023 | 11:07 PM
ajchien's Avatar
I’d probably check to see if the temp switch was stuck on.
Old Dec 14, 2023 | 07:53 AM
The AC fan may have a stuck relay. If you applied power and ground to the other fan and it did nothing the fan motor has open windings and needs to be replaced.
Old Dec 14, 2023 | 11:50 AM
Mcfam's Avatar
Swapped relays no change, but if I unplug the temperature sensor on the radiator it comes on and off with the a:c switch. Do I replace the sensor or is there something else wrong in the wiring?
Old Dec 14, 2023 | 03:33 PM
Bubbalou88's Avatar
​​​​​​​To me it sounds like the radiater temp switch is shorted providing constant ground.
Old Dec 15, 2023 | 08:54 AM
  #10
Download the service information. Link is provided by
https://www.crvownersclub.com/thread...ersion.217090/
clkinaz
Oct 30, 2020 02:37 PM
Cultcab
Jun 27, 2020 12:15 PM
dx277
Mar 24, 2015 09:25 PM
rsolorio
Feb 12, 2009 11:27 PM
thedaveman89
Jan 8, 2009 12:46 PM
