2006 accord signal issue
Old Aug 22, 2018 | 08:57 AM
Mike178's Avatar
Default 2006 accord signal issue
I have a 2006 Honda Accord ex 2 door. I am having signal issues. Left and right signal is blinking rapidly. When headlights light are off and signal is initiated signal light is blinking but VERY dim barely seen. When headlights are turned on signal still blinks at the same dimness and cannot be seen at night. This issue is only for the front signals. Rear sgnals are blinking fast as well but the brightness is working perfectly. Ground near battery was checked. Fuses fine. Flasher relay and signal bulbs have been replaced. Still having issues. Also want to note that hazards blink at nornal rate but signal bulb still dim in headlights. Any ideas ?
Old Aug 22, 2018 | 05:06 PM
welcome to the forum have you changed the hazard switch?
Old Aug 22, 2018 | 05:31 PM
Mike178's Avatar
Hi, thanks! I have not changed the hazed switch. Could that be the issue even though the hazards are blinking at the normal speed? The car was painted recently and new headlights were put in.
Someone today told me the headlights might need to be pulled out to see if a wire is touching metal where it shouldn’t be or if a wire could be pinched causing the signals to not illuminate bright like it should. I am super stumped on the problem.
Old Aug 22, 2018 | 09:35 PM
did not know the headlights were replaced. you might want to check the headlight wire installation before you touch the flasher switch. sounds like you might have changed all the parts for good measure if you find a bad or incorrect hook up of the head light wiring.
Old Aug 22, 2018 | 10:12 PM
Mike178's Avatar
will work on that. Thanks!!
Usen
Jul 10, 2021 12:02 PM
Kelsey
Jan 18, 2018 09:33 PM
mattjaja
Apr 24, 2013 07:58 PM
broguearcher
Mar 24, 2009 02:06 PM
haioiii
Feb 8, 2007 02:05 AM
