AC/Heater motor stopped working
Old Oct 31, 2010 | 06:27 PM
jamesp81's Avatar
Default AC/Heater motor stopped working
This is on a 2005 Honda Accord. The fuses don't look blown. My understanding is that this is usually a result of a bad resistor or transistor for the blower motor. I don't know how to get at that stuff though and was wondering if someone has a diagram showing how to get to the wiring I need to examine.
Old Oct 31, 2010 | 06:57 PM
91haydenSI's Avatar
im not sure exactly where everything is but this website should definately be able to help http://diagramwiring.net .. if not just go to the dealership they can print you off a diagram (the will try and heckle you into bringing the car in but it will cost a lot) but the service department can print you out a diagram if need be.. and its free
Old Nov 1, 2010 | 07:27 AM
Welcome to the forum,I would pull the fuse and look at it close,I have seen fuses blow and at first glance look OK,worth a try.Then check out the site 91Hayden gave you.
Old Nov 1, 2010 | 08:44 AM
jamesp81's Avatar
I actually swapped out the relevant fuses (at least I think they were the right ones) with known good fuses to no effect. I will check 91Hayden's link.
Old Nov 1, 2010 | 08:48 AM
jamesp81's Avatar
It's not a wiring diagram that I need so much, as I need to know which parts of the dash to remove, where the screws are, stuff like that.
Old Nov 1, 2010 | 10:58 AM
91haydenSI's Avatar
Oh well in that case i would either go to your local auto parts store and grab a repair manual (those things come in handy more than you think lol) or just swing by the dealerships service department and ask them to print you up a diagram (this is something i do when the repair manual isn't detailed enough)
cfauvel
Sep 22, 2012 09:36 AM
r1013
Mar 12, 2009 11:49 AM
stevel
Jun 28, 2008 09:48 AM
nickl
Nov 26, 2007 09:43 PM
