Radiator fan
I have a Honda pilot 2004 the radiator fan works iwhen I on the AC or when the engine gets to a certain tempreture.
But I want the fan to work when I on the ignition so can I pass the fan to work directly . Thanks
yes you can, place a hot switch directly to the fan using a fuse for safety and turn on at will with engine running or not running. with ignition off . just be aware if you forget to turn the switch off, your battery will go dead.
The attached photo is for reference only to show the space with blue fuse is for ignition fuse and yellow fuse placement for the relay coil via the switch that will energize the relay that will manually turn fan on and off.
You nees to get correct style holder for your particular car
